Help me decipher my state's Fender and Mud Flap law
  • 3
qtipextra
The Original
I am trying to make sure that my Durango is within legal specifications, but I don't exactly understand the wording.
49-949.Requirement as to fender or covers over all wheels on motor vehicles. (1) It shall be unlawful for any person to operate or move or any owner to permit to be operated or moved, any motor vehicle, truck, bus, semitrailer or trailer, upon any highway without having the vehicle equipped with fenders or covers which may include flaps or splash aprons, over and to the rear of wheels, as follows:(a) On the rear wheels of every truck equipped with a body, bus, trailer or semitrailer the fenders or covers shall extend in full width from a point above and forward of the center of the tires over and to the rear of the wheels to a point that is not more than ten (10) inches above the surface of the highway when the vehicle is empty;
(b) Behind the rear wheels of every truck not equipped with a body the fenders or covers shall extend downward in full width from a point not lower than halfway between the center of the wheels and the top of the tires on the wheels to a point that is not more than ten (10) inches above the surface of the highway when the vehicle is empty;
© Behind all wheels of every motor vehicle other than trucks, buses, semitrailers, or trailers, the fenders or covers shall extend in full width from a point above and forward of the center of the tire over and to the rear of the wheel to a point that is not more than twenty (20) inches above the surface of the highway, unless the bumper is a factory built bumper fastened directly to the frame of the vehicle pursuant to factory installation requirements;
(d) Fenders or covers are not required on any modified American-made pre-1935 vehicle, or any identifiable vintage or replica thereof that is titled as a later assembled vehicle or replica and is used for show and pleasure use when such vehicle is used and driven only during fair weather on well-maintained hard-surfaced roads.
(2) Fenders or covers, as used in subsection (1) of this section, shall be deemed to be of sufficient size and construction as to comply with those requirements if constructed as follows:
(a) When measured on the cross sections of the tread of the wheel or on the combined cross sections of the treads of multiple wheels, the fender or cover extends at least to each side of the width of the tire or of the combined width of the multiple tires, as the case may be;
(b) The fender or cover is constructed as to be capable at all times of arresting and deflecting dirt, mud, water, or other substance as may be picked up and carried by wheels;
© For school buses if the body extension behind the rear wheels exceeds five (5) feet.
I understand from reading this that I need to have a mudflap behind the rear tires to a point that is not more then 20" above the street.
The fender covers part is what really confuses me. Its kind of worded as such that the fender needs to be as wide as the tire's cross tread, but does not need to extend over the entire width when the tires are mounted to the vehicle. But then I read it again and I can see that they are implying that it must cover to each side.
Maybe i'm just overlooking it. Im pretty sure the entire tire width has to be completely covered by the fender width as it sits on the vehicle.
Is that how you interpret this?
Hmm. .. Sounds like the MI law. I think it means not to have your tires width extend past your fender due to rocks slinging... ect. Fender Flares fix that. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Yeah that is what I am thinking. I have been wanting to get fender flares anyways, but they are pretty pricey.
I believe that the LC2i has a fixed subsonic filter at 33hz, that will affect the low end too. THe LCi2 pro has a set filter at 22 hz, better...
28
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
220
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
12
650
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
406
qtipextra
The Original
qtipextra
Idaho Falls, Idaho
qtipextra
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
