HELP ME PLEASE!!!!
NYCNIGGA78
Hello and good day to you all. I have a 1998 Mercury Sable LS with the MACH Audio System and I want to add a cd changer to it. I went to the Crutchfield website and I found it to be very confusing. I would like to know what kind of cd changer is available for my car and where can I buy it from. Also please note that I my car has the oval radio/cd/environmental plate and it is a factory install.
Thank You All,
Dana
i know crutch field has an adpter for that oval that will allow you to use a single din sized headunit, and just moves the ac controls a bit, other than that i cant offer much
maybe try a local car audio store. circut city even. If I understand you correctly, you are trying to keep the factory radio and add an aftermarket changer. It can be done there are several companies that make this plug, and it will tell you which changer you need to run with it. The alternative is rf modulated which links into your fm. Although sound quality is lost a little it works and the changer you buy usually will link up to the aftermarket head should you ever change your factory one out.
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
957
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
NYCNIGGA78
NYCNIGGA78
Norfolk, VA
gregj9
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
