Help me understand this battery.
FamousMassacre
Team Tantric
For my battery, I had a guy work on my system and when he unscrewed the terminal off of the battery, the battery turned off(when it reconnected, everything was reset).
I don't understand what made the battery to turn off? Really all that was removed was the nut.
When the battery was off:
When it was still connected:
Maybe i'm seeing something wrong then. But it looks like everything was taken off the positive terminal on the batt. That's the only reason everything would have been reset and such..
Battery working:
Battery not working:
The only difference is the terminal and nut. I saw him just get a drill and take off the positive nut.
40-85l is about the size range most high powered 12" woofers will want for a box. You should use manufacturer suggested box specs unless someone...
417
522
538
FamousMassacre
Team Tantric
FamousMassacre
San Antonio, Texas
Timmy13091
