Help me.....
How is your headunit grounded.
Sent from my draconis using Tapatalk
it isnt... never has been ... all of this started when i had two channels go bad on a set of 4ch rcas... just went and bought two sets of ground loop isolators is has deminished it but its still there and if i hook up ground wires on isolators its twice as loud as before.... //content.invisioncic.com/y282845/emoticons/rage.gif.0ad8a6e5565b5fddce406566fdd05149.gif lol tried grounding rcas to hu didnt work...
So your headunit is not grounded by the ground wire to your car chassis?
yeah but i never followed the lil black wire into the dash i wired at harness but other than that no extra grounds... so change stock location???
A ground wire grounded near or at same location as engine ground can produce engine whine.. Use a sheetrock screw or metal screw to create your own ground if the chassis runs behind your radio or near it.
will do... thanks
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
504
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
542
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
575
basswiigee2fix
basswiigee2fix
michigan
SPLxCountry
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
