Help Needed. Sub Amp Hissing
  • 3
This just started recently. Maybe 5 days or less. It happens when I turn off my vehicle and have been playing the music loud. I also hear the amp clicking like it's turning off after the hissing has stopped. This is the first time I've heard this happen.
The amp in question is a PG QX900.1D and is attached to the back seat of my SUV.
Thanks for your input and help.
So this happens when your vehicle is turned off and audio off?? Could be the internal parts "relaxing". Or remove the cobra within your amp
Hahaha.
Yeah, I hear the hissing noise as soon as I turn off the vehicle and the hissing usually lasts around 3-5 seconds then stops followed by what I assume as the amp powering off by making a clicking sound.
Never heard it before until just recently
Sounds like the soft on/off circuitry is not working properly, the noise you're describing sounds like the caps emptying after power is removed. This happens in all amps but you don't usually hear it because the circuit cuts the outputs upon the "off" trigger.
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
535
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
9
Thanks for this! Yes, there are 6.5 door speakers, front and back. I've heard them referred to as woofers but I'm sure their frequencies included...
11
drei4runner
Los Angeles, CA
ciaonzo
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
