Help needed: Subwoofer settings cause crackle
  • 1
Dylan2996
CarAudio.com Newbie
Hi guys, so i've had this pioneer unit in my SUV for a while now (years).
The other day it started producing a crackling noise in all the speakers (doors, dash, sub). When i go into the settings and turn off the subwoofer the problem goes away and everything sounds perfect.
I disconnected the audio cables from the unit itself and it still makes the noise. I've also tested the amp/sub separately and it works fine. Problem appears to be with the unit itself and only when the subwoofer settings is switched to ON.
Any ideas or suggestions? Thank you in advance!
Equipment: Pioneer AVH-270BT
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
480
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
9
Thanks for this! Yes, there are 6.5 door speakers, front and back. I've heard them referred to as woofers but I'm sure their frequencies included...
11
Dylan2996
CarAudio.com Newbie
Dylan2996
Dylan2996
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
