HELP NEEDED wiring in new head init.
  • 2
phil99
I need some help with wiring in a head unit in an old van. I just bought a 1990 Nissan Caravan and the spanner who had it before me did a bit of d.i.y on the wiring and now it doesn't fit any adaptors. How can i find out which wires are which so i can connect up each wire individually?
Cheers
Phil
Could be this...
1987-90 Nissan Van Stereo Wiring
Constant 12V+ Red/Black
Switched 12V+ Blue
Ground n/a
Illumination Red/Yellow
Dimmer n/a
Antenna Driver's Pillar
Front Speakers 5" Doors
Left Front (+) Blue/White
Left Front (-) Blue/Yellow
Right Front (+) Brown
Right Front (-) Brown/White
Rear Speakers 5" Side Panels
Left Rear (+) Red
Left Rear (-) Green
Right Rear (+) Blue
Right Rear (-) Pink
Thanks for your help mate but it doesnt seem to match up.
I have,
1 smaller wire harness with
2 black
1 pink
1 red w/white stripe
One larger harness with
1 black
1black w/ white stripe
1 red w/ blue stripe
Note, the van seems to only have one speaker on the dash.
Do all the powered wires lead to a fuse board?
Cheers
Phil
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
555
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
9
Thanks for this! Yes, there are 6.5 door speakers, front and back. I've heard them referred to as woofers but I'm sure their frequencies included...
11
phil99
phil99
auckland
phil99
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
