help newbie with alarm install..
  • 2
pl8rzclub
hi i am a newbie to this forum.....
i have a '95 Acura Integra trying to install the keyless entry alarm..the name brand is astra 777....well i got the alarm part to work but i just can't get the keyless part..i can get it to unlock but the lock part just don't work...it locked once then nothing happened after i tried to use it agan...i have the right wires becase i did a search on it..does someone know what i am doing wrong??? and also if i did manage to burn the lock wire, can i use a relay to install the lock to one of the auxillary buttons?? if someone knows how to please let me know or if someone has any suggestions please let me know...
thanks in advance..
Does the vehicle still lock with the factory switches? If not, check all your fuses. If it does, then either the problem is with the alarm or you have the wrong lock wire.
yes the vehicle still locks with factory switches..i rechecked the wires and they say it should be the wire i am using..and no fuses were blown..still don't know what is wrong???
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
128
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
436
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
413
pl8rzclub
pl8rzclub
arkansas
pl8rzclub
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
