Help on rca’s
  • 2
PICKELITESOUNDZ
21
Chicago
I have tweaters 6.5’s 8’s and subs  2 4 channel amps and 1 bass amp and a eq   The eq only has front rear and sub   So the tweaters are going to front and would I use y splitters and put the 6.5’s and 8’s both on rear? What would be some options  I would like 8’s to start at 125 and the 6.5’s a little higher cause they don’t sound very good with that much mid bass so I was thinking 200-250 to get away from the lower mid bass
Where are you getting your EQ function from?
Which speakers to put on front or rear of the EQ depends on what fader control you want... assuming the EQ has a fader adjustment.
It's fine to run the 6.5 as high as you want since you have 8's for midbass.  FYI, I run my 6.5 down to 60Hz, so you can take the 8's lower if you want.
So you're planning on running active and using the amp or head unit crossover for the tweeters? Is that sub channel full range and have separate...
950
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
149
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
360
PICKELITESOUNDZ
PICKELITESOUNDZ
Chicago
keep_hope_alive
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
