Help Please, Alpine PDX 1.100
  • 1
Soares_BR
5
CT
Hello, i previously had this setup in a ported box and recently decided to build a new sealed box with approximately 2cu ft for two Alpine SWR1243D 12" subs wired to a PDX1.1000 amp.
I was wondering what settings i should have my gain and other settings on my amplifier to prevent any damage to be done on the subs. For listening every day at moderate volume etc....
Any help is greatly appreciated !
Thank You
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
955
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
Soares_BR
Soares_BR
CT
Soares_BR
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
