Help Please! Battery/Way Around Upgrading My Alternator?
  • 3
1EdgeKilla
So heres whats up, I drive a 2002 Chevy Cavalier with a stock alternator (80 amps I believe). When everything is said and done i'll be running two Alpine PDX amps...the M-12 and F-4 for a total of 1300 watts rms. From what I understand and know they are one of the more efficient digital amps out there. On top of that, I'll have all 0 gauge wiring including the Big 3.
Now, my issue is I don't really want to go through the hassle of upgrading to a H/O alternator if i don't have to or can get around it. My question is if its possible to run this system safely and efficiently off the stock alternator by just upgrading to a say a optima or kinetik battery?
a detailed explanation of advice would be greatly appreciated and will thank anyone who can help me out!
The only real way to tell for sure IMO is hook it all up and if your lights dim then you know you have to bite the bullet and get a ho alt. Some shops can just upgrade your stock alt to become a ho alt too. Also you should buy a deep-cell batt and try to get a yellow or red cap. Makes sure all connections are clean too of course.
All your car battery does is starts the car. When the car is running, it's all on your alternator. So changing your battery won't make a difference, unless you're talking about playing your stereo with the car off.
If I had to guess, I'd say that your 80 amp alt is not going to keep the headlights from dimming, but as the other guy said, there's one way to find out.
well thats also something else to consider because i do use my car a lot for music purposes outside of when im driving such as the good old partys in the fields and in the middle of nowhere...and i dont exactly want to have my car running the whole time but i could see where your coming from with the whole have to try it out
Well if you want to play your tunes with the car off, you'd better plan on doing alot more than just replacing your 1 battery.
More like plan on getting a whole bank of batteries and even then with the car off it will only last so long.
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
962
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
1EdgeKilla
1EdgeKilla
Williamsport, PA
ColterDC
Doxquzme
    May 19, 2024
Dylan27
    May 19, 2024
