Help Please, Comment on New System Setup
  • 3
fishingfromakay
MA
Hi, I was hoping to get some thoughts/ideas/comments on the system I am planning on getting. So any help is appreciated, thnx for ANY help
Music I like- Metallica and Top 40
Car- 2008 Nissan Frontier Crew Cab
Head Unit- Sony WX-GT90BT
Amp- Clarion XC1410 , 50 watts RMS x 4 at 4 ohms (75 watts RMS x 4 at 2 ohms)
Front Speaker-JBL GX963 , Sensitivity 94 dB at 2.83 volts
Frequency Response 45 - 21k Hz
RMS Power Range (Watts) 2-100
Peak Power Handling (Watts) 300
Impedance (Ohms) 2
Rear Speakers-Sensitivity 93 dB at 2.83 volts
Frequency Response 55 - 20k Hz
RMS Power Range (Watts) 2-45
Peak Power Handling (Watts) 135
Impedance (Ohms) 4
Hi, I was hoping to get some thoughts/ideas/comments on the system I am planning on getting. So any help is appreciated, thnx for ANY helpMusic I like- Metallica and Top 40
Impedance (Ohms) 2
Impedance (Ohms) 4
How much you're spending on all this? Chances are, you may have enough for a 5ch amp, which you can use to power a sub as well. Metallica is one of my favorite bands and I've listened to every single song dozens of times. When the drums hit, you'll need to do them justice with a sub.
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
fishingfromakay
fishingfromakay
MA
fly_marlin
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
