Help Please kenwood dmx2050dabs
  • 1
mitch3496
CarAudio.com Newbie
I have a seat Leon 2010 1.6tdi it’s fitted with a seat unit that won’t load sd card internal error so bought the above stereo to upgrade and a fitting kit(connects 2 patch) not as straightforward to me as I’m total newbie
I thought it’d be just plug and play the patch has a green wire orange wire and purple wire so snip the orange and green leaving purple for kenwood then on diagram says use key 1 to radio but where abouts on the head unit does key 1 go to??after a frustrating getting nothing off the internet starting to think a lot of £’s down first of all trying to save original seat head unit by trying different sd cards but to be honest don’t think it’s the right unit for the car then £’s out on the kenwood kinda frustrating easy fix for tech not for me it’s just for swc please help the 3.25 jack is for alpine only I think il forward the loom and diagram pics
On the back of the head unit is green wire I take that is for the brake then there’s different inputs for swc remote etc and reverse and ground cheers in advance
Maybe just give up and get a grammar phone in the boot
Many thanks in advance for any help it’s well appreciated
Davy
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
970
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
mitch3496
CarAudio.com Newbie
mitch3496
highland
mitch3496
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
