help please vss for chrysler 300
erik019
IN
i just brought a avic-d3 and i am trying to locate the vss (vehical speed sensor) i cant find this information no where on the net any information anybody have would be helpful i have a 2005 300 limited edition. thank in advance
what year 300,some of the can-bus harnesses have the vss wires for in dash nav units
like the peripheral chyah05
which if your car is 05 and up should already have
would this work for the parking brake, reverse, parking light and VSS output wires on a 2005 chrysler 300 even if my car did not come factory with the nagavation unit
dont try and search for it!! make it easy and use the chyah05 comes with speed sence wire in the harness. along with stearing wheel control wires..... you are going to need this style of wire harness anyways, so make it easy on urself....
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
erik019
erik019
IN
SethPhillips
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
