HELP! problems with autopage rs-1000 alarm
  • 1
jdminh
okay so i lost my remotes with my keys to my car and i had to get it replaced. but when i took it to the honda shop to get my key made, they unplugged my alarm and but then i told them that they unplug something else cause now my lock button doesnt work and my led light comes on everytime i press the brake. is there a way to fix all this? and does anyone know where i can find a cheap replacement remote for my alarm? thanks!
Based off GM pickups of the same year (and that was GM), It SHOULD just be for the vehicle sounds that play through your stereo, such as the door...
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
525
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
550
jdminh
jdminh
Wichita, ks
jdminh
