help! rear speakers fading out between r and l sides..
  • 1
luke32303
I have a 4 channel amp run from an electronic crossover and recently the rear speakers have been acting up. Either one or the other will work, usually not both. If I turn up the volume pretty high, the one that isn't working will sputter and come on for a short time, then it usually goes back out. Sometimes the right rear will make a popping sound. The 2 front components work fine all the time. Anyone have any idea what is going on?
915
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
467
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
531
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
563
luke32303
luke32303
Jacksonville.FL
luke32303
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
