Help selecting a encloser for my new sub!!
  • 2
HomeyDClown
I just got a Diamond Audio HP12 sub. I'm looking for the right enclosure for it. I know that buying/building a custom box would be perferable but I lack money tools and time to do it.
I have been trying to find a vented box that will fit in my trunk and match the subs requirements.
Here are the requirements for the sub
Air space (vb) = 1.75
fb/f3 (Hz) - 35/29
Port/s (in)(dia X length) = 4 X 16
pe (W) = 1000
Mounting depth = 8
Displacment = 0.15 ft3
The box specifications are
12 Single Labyrinth Vented Subwoofer Box 1.86 Cu Ft Air Space
Height: 14 3/8"
Width: 20 1/8"
Depth: 16 3/8
1.86 Cu Ft Air Space per woofer
Tuned at: 36 Hz
Cut out diameter: 11 1/16"
Mounting depth: 11 7/8"
Holds one 12" woofer
Material: Premium USA MDF
Material Thickness: 3/4"
If the vent frequence is off by 1 hz, what effect will it have? Does anyone have an opinion on Obcon labyrinth box (good or bad)? Is this going to be a good match?
The area of my trunk is about 23 inches wide, 14 inch tall and has a depth of 16 inches. So I want to stay in that size range.
That box isn't too bad for a prefab. But why not go custom? You'll get things like 1 1/2" front baffles, flush mounting, etc. I'd also go about 2.5 cubes tuned to around 30 or so. But that's just me. I prefer larger boxes that are tuned low and manufacturer's specs are usually too small imo.
Hey everyone.. sorry I didn't get notified that i has more responses to this thread. The porsche sold a couple weeks ago lol I'll miss it but I...
29
4K
So they'd be connected together with the normal two front speakers? Would need to match the ohms/ watts of the tweeters and door speakers?
5
If you have an OEM radio and amp, chances are that one has bass reduction as the volume rises to protect the paper cones from tearing apart. So if...
6
83
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
122
HomeyDClown
HomeyDClown
Sacramento
DoesDad
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
