Help wiring MTX Re-Q5
  • 3
fuze
Hey all,
I am trying to add a 10" Alpine Type R subwoofer and a mono amp to my stock 4 speaker car audio system in my 08 Charger. (There are only 4 speakers in my car, 2 in front 2 in back.)
Here is what I purchased(many months ago, just now trying to install it)
10" Alpine Type R
Boss Audio Onyx NX1800.1 amp
MTX RE-Q5
I used an amp wiring kit to hook everything up, and it looks like the power and remote side of things are fine. Both the amp and the RE-Q turn on when my key is turned in the ignition and both have the power lights on.
Im stuck on how to wire this RE-Q to get the signal for my new subwoofer.... I tapped into my rear speaker and connected it to the RE-Q wiring harness but nothing is happening.
I feel really dumb right now.... thought this was going to be as easy as tapping into a speaker wire but apparently im missing something.
any help would be great lol
make sure you tap at least two speakers so it can sum a stereo load. i have one and it works like a charm in my cruze also check you gain settings on the req5 since it is also a line booster you can have them set to zero and get zero sound. i just set them half way and adjusted my amp gain to match the req
hey man, i went back and tapped into both right and left rear speaker and nothing changed.
But then I connected one of my speakers to the White/Red and White wires on the RE-Q harness and finally I got audio through my sub. The White/Red wire is labeled "Front Left" but does it matter if I use that one tapped into a rear speaker?
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
659
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
7
Your image doesn't really show anything. That could be 3 different head units for all we know, but I think it's 2 different add-ons. It sounds...
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
fuze
fuze
Michigan
fuze
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
