HELP!! wiring noob
  • 5
The subwoofer you linked is already wired to 2-ohms. It has one set of terminals - just connect them to the amp output - done. No diagrams needed. You do NOT need to re-wire those subs to 4-ohms. That sub can handle 600W RMS continuous power. (300 W RMS per sub) (Forget about the peak watts - this is a useless spec - pay attention to RMS watts)
You need an amplifier that is 2-ohm stable and will put out between 300W RMS and 600W RMS into a 2-ohm load. The amplifier you linked is overpowered (1200W RMS into 2-ohms) for that sub - it is 2-ohm stable and would work, but be very careful setting the gain.
This amp would work just fine if you are dead set on Kicker and Bestbuy--> Kicker CX Series CX600.1 1200W Class D Mono Amplifier with Adjustable KickEQ Bass Boost 12CX6001 - Best Buy
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
679
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
Your image doesn't really show anything. That could be 3 different head units for all we know, but I think it's 2 different add-ons. It sounds...
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
bassinmytruck
bassinmytruck
Wichita, KS
Jepalan
