help wiring subs....
  • 4
freakin_rican
hello folks i have a simple question i am going to be hooking up a pair of these subs:Audiobahn AW121T 1100W 12" Flame Excursion Series 4-Ohm Car Audio Subwoofers to a Memphis 16-ST500D amp and my question is how do i wire the subs to the amp for the best possible sound subs will be put in a sealed box...i know this stuff is old equipment but they are in real good shape and still work so might as well get use out of it...thanks for any help...
can i do this with that amp...
hmm....I had a ST-1000D that was 1ohm stable....I researched the ST-500D and your question is valid, it is a 2ohm stable amp. I did not know that. Looks like wiring them to 4 ohms for 125 watts ea is your only option there. I would look into another set of subs or a more powerful/or 1ohm stable amp.
---------- Post added at 11:07 AM ---------- Previous post was at 11:07 AM ----------
http://www.memphiscaraudio.com/documents/PriorToStudioseries%20classDmonoblock_subwoofer_amp.pdf
Are these subs dual 4 or single 4...??? Thanks for the info and links...
Look at the listing for your woofers, if it says anything along the lines of "SVC" or "Single Voice Coil" you have single 4 Ohm subs, if they say "DVC" or "Dual Voice Coil" then you have dual 4 Ohms. The only difference is that the single has one terminal with negative and positive outlets, and a dual has two.
hey thanks for the info these have two sets of - and +
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
542
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
7
936
freakin_rican
freakin_rican
whitehall michigan
freakin_rican
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
