HELP WIT AMP FOR MIDS
  • Thread starter <Falkofire>
  • Start date
  • Replies 2
  • Views 1K
  • 2
<Falkofire>
Guest
HOW DO I HOOK UP MY AMP FOR MY MIDS, I HAVE A 2 CAHNNEL AMP AND I HAVE 4 SPEAKERS TO HOOK UP TO IT, AND I ALREADY HAVE SUBS AND AN AMP FOR THEM SO AM I GOING TO NEED LIKE A DISTRABUTION BLOCK OR SOMETHING ANYWAYZ THANX
hi,
Yu also can use them in parralel or series. excuse my Englisch, i'm dutch. but in series the imdadance goes from 4ohm to 8ohm and in parralel use it will be 2 ohm's, i hope you'r helped with this
falkofire-how much power per channel
does you amp has
are your 4 speakers -4ohm or 8ohm speaker and are they
(componets- meaning midrange and tweeter) and do
they have passive crossover for them. or are they
(coaxles or 6x9 speakers) also what power gauge
wire do you have comming from your battery
to your amps
507
543
577
Guest
billetz23
