Help with a frankenwoofer
  • 3
truckcap22
ky
So I've been out of the CA game for a while, but the urge is coming back strong. I have the capability to pick up a trf 4hp motor with a 15" aq hdc basket attached. I was curious as to the possibilities I could go with this setup. Would someone be able to give some suggestions as far as if I should pick this combo up and what to expect from it? Thanks!
Would I still be able to get a recone with that basket? I don't mind paying to get it rebuilt, I just don't want to get it to find out that I have to get a different basket. I'm assuming PSI or someone could fab something up to make it functional again?
Start off by making sure the ground is making contact with bare metal. Then check that the fuse holder wires by the battery are snug. When I have...
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
572
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
574
truckcap22
truckcap22
ky
mazdakid
