Help With Configuring Sstem, Please
  • 1
Core-Lokt
Texas
Hello, all. I'm going to start off by saying I don't know really anything about car audio. I know you'll need specs on stuff to help. I now know I don't have the basis for a hard-core audiophile's setup, and that's fine. I simply want some improvement.
Now, the current system. It's an Android HU which I value for internet and computing. The four stock factory speakers were replaced with some Kicker DS-series with specs below.
Front doors: 6X9; power 2-90W RMS, 360W peak, 4 ohms impedance
Rear doors: 6.5; power 2-60W RMS, 240W peak, 4 ohms impedance
I also have a pair of 3.5" speakers I've yet to install as I decided I'd want to ask on how to proceed. They are also Kicker DS-series.
Dashboard: 3.5; power 20W RMS, 80W peak, 4 ohms impedance
I would like to know what size amplifier to purchase, should I have a sub-woofer (and can an amplifier power it or does it need separate amplifier) and what gauge wire for the amp(s) cables and speakers. I found out about line output converters, but I'd rather not use one of them. I'd prefer to run new wires.
I watched some videos on installing an upgraded system in a Dodge Ram pickup and the amp used was specifically mentioned as being compact. So, I'll include a link to it. PN5.640D | Soundstream I have a hard-wired inverter under the rear seat, so compactness helps.
If there's anything else you need to know, please ask. Thanks in advance for any help.
There's definitely quite a few that can give a better answer, but IMO, it's (1) 8" sub. It's supposed to be quicky and jabby, not a power...
7
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
367
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
513
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
519
Core-Lokt
Core-Lokt
Texas
Core-Lokt
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
