Help with distortion in Midrange speakers! Driving me crazy!
  • 2
kemo9099
Hey guys. I need some help solving this issue because its driving me crazy! Cant figure it out.
Firstly, my setup:
Car: 2012 Challenger SXT
Audio Spec:
Stock Head Unit- Using Step down converter to RCAs
audicontol Line Driver- Six Channel 1st channel- Mids 2nd & 3rd Channel- Sub
audiocontrol 3.2 equalizer
Amps- 2x t1500-bd rockfordfosgate, 200 rockfordfosgate punch
Speakers- Infiniti Kappas 6x9s front doors and 6 1/2 rear dash; 12in Orion HCCA 4k watt sub
OK, so this is my problem. After hooking up everything, it all sounds great! Highs are crisp and clean and bass is seriously knocking. BUT, I just noticed that in low volume like around 12 on the head unit and the bass is hitting, there's distortion from my mids. I turn down the sub via the equalizer and bump just the mid range no problems at all. But then I kick in the sub and I know notice even in high volume that there is some slight crackling and even popping when the subwoofer hits.
Ive checked the grounds, checked for loose wiring, adjusted the line driver and gain on the amp. I'm not quite sure what the deal is.
Is it a grounding issue with the amps or maybe with the rcas? Or perhaps the sub amps are drawing too much power that its causing a spike for the midrange? Maybe need a small cap for mid-range? Or maybe need to adjust equalizer/ line driver?
Any suggestions would be greatly appreciated!
could be the sub pushing on the rear deck speakers, causing them to distort under the pressure created by the sub. this is very common.
another option is voltage drop. when the sub amp pulls voltage down, the supply rails on the speaker amp will sag and clipping is possible.
are you sure it's not the sub clipping?
Sounds like he has a Mono amp.. Pics of said amplifier you are using OP 👀 👀 Lets see what amp you have
21
update: still don’t know what’s wrong, but Kicker customer service is great. easy back and forth via email and they are sending me a pair under...
11
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
69
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
9
113
kemo9099
kemo9099
Seattle, Wa
keep_hope_alive
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
