Help with enclosure for 12" aq hdc4
  • 5
Im still a beginner when it comes to designing my own enclosures but this is what I came up with so far.
28" x 15" x 22.5 (.75 for double baffle)
port: 4" x 13.5" and 42" long to be at around 35-36 hz (54 sq inches of port or 21.6 per cu ft)
gross: 4.14 cu ft gross
2.50 cu ft net before displacement.
Does this seem correct and does it seem to be like a good enclosure design?
I always thought aq loved the port area?
meh... they dont have the strongest motor out there... so a larger box and a little smaller on the port area is optimal IMO.. 21 is pretty high either way. 17 would be perfect. highest I would go is 18
little less port area. go for about 16-17 per cu ft.
Enclosure volume does not effect port volume.... The displacement capabilities determine the port area of the subwoofer. Since AQ doesn't list the Xmax of the sub I'm assuming its around 25mm, with a tuning of 36 hz 50in^2 of port area would be about the minimum I would use.
I used BASS Box Pro. It’s what parts express uses on most all their woofer spec recommends. I didn’t build the box phisically that is. I also...
9
Just remember when you pick a tuning frequency as you go higher the box gains efficiency, but loses low end and tends to become peaky.
Here’s another idea I was thinking of. I’m doing a single 12 in the center of the box just for aesthetics I was wanting ports on the sides of the...
  • Poll
I have those specs but the actual order layout is sketchy if u go out of spec a lil ur toast
7
It depends on how cheap you wanna go but I've had excellent results with a 12inch power acoustic gothic sub in a small sealed enclosure for budget...
72
8K
myjaja
Audioque
myjaja
San Antonio, Tx Posts: 143,632 _____<^>*_*&l
myjaja
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
