Help with enclosure for two 18" Incriminators
  • 2
I have 28" of depth and the subs will be firing upwards, port firing rear. So the two 8" or a 10" will work. So the lengths you gave me are included to my 13 cube box right?
Yep... I added some bracing too (dowels) and driver displacement... 17" long... remember to add 1/2 flare radius to the length on each end
I used BASS Box Pro. It’s what parts express uses on most all their woofer spec recommends. I didn’t build the box phisically that is. I also...
Just remember when you pick a tuning frequency as you go higher the box gains efficiency, but loses low end and tends to become peaky.
Here’s another idea I was thinking of. I’m doing a single 12 in the center of the box just for aesthetics I was wanting ports on the sides of the...
  • Poll
I have those specs but the actual order layout is sketchy if u go out of spec a lil ur toast
It depends on how cheap you wanna go but I've had excellent results with a 12inch power acoustic gothic sub in a small sealed enclosure for budget...
72
8K
Incrimin18s
Incrimin18s
Florida
shredder1
    May 19, 2024
    May 19, 2024
