help with grounding
  • 2
uzy
O
hey
i have my amps installed by a friend who has done a bit crappy as the controls are on the end of the amp facing the floor of the boot lol.
so to use the controls i want to turn the amps the other way round the +ve wire is fine but the ground wire was done in 2 different places, so the two amps were grounded on a bolt in the boot space while the power cap was ground to the seatbelt bolt. would it be aright if i was to put the ground cable from both the amps to the ground point on the power cap, so that they go through the power caps ground wire to the seatbelt bolt.
You should run a ground from the battery to a location where you can put all your grounds at that point.
If you want to put your grounds at that seatbelt bolt it should be fine.
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
512
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
546
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
578
uzy
uzy
O
Team Hammer
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
