Help with Jensen cdh1000 installation in 94 mustang gt conv.
  • Thread starter <kmccalli18>
  • Start date
  • Replies 1
  • Views 2K
  • 1
<kmccalli18>
Guest
I am going to install a jensen cdh1000 head unit in my 94 mustang gt. Do I have to remove the dash, or just insert the proper tools into the four holes of the factory unit and pull it out???
Also, will I need the harness or not???
you can get the tool you need at walmart for like 3 bucks, or if you are careful and have 4 allan wrenches that fit in the holes you can use them. If you buy the tool it is shaped like a u and is just a tunning fork looking thing
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
528
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
551
I went with Kenwood Exelon. Audio Control amp and speakers. It’s amazing! I’m glad I did some research before buying. Thanks guys.
5
619
Guest
gregj9
