Help with LOC gain
  • 2
dragonballz
MA
I have a 2006 Civic with the stock headunit. I hooked up a Tsunami LOC to my rear speakers. I am setting the gain by hooking up the RCAs to the LOC and taking voltage readings from the other end of the RCAs. The voltage goes from 0 to .4xx volts. Four-tenths of a volt with the knobs maxed out. Isnt it supposed to go higher than that... like around 4 volts? I played a 70hz test tone at 30/40 volume (75%).
The RCAs are going to my amp to power a 400w RMS subwoofer.
Even though the pre-out voltage is less than a volt, the speaker-out on the amp is able to reach the correct voltage while setting the amp gain using DMM method. The subwoofer sounds fine too.
This LOC has been installed 3 years ago and I am re-installing it after going back to my stock headunit after removing my Alpine headunit. I dont recall the voltage not being able to reach 2 or 3 volts.
Why is it so low?
Thanks
Thanks for the reply.
Wouldnt there be a chance that I could clip the signal by setting the LOC to max? I dont have access to an oscilloscope.
Okay I'll try that. The connections are so close together. It seems kind of silly really.
8
887
Yes, use left and right RCA inputs on the amp. Did the LOC turn on? If not, check for a button or switch on it to activate the signal sense...
5
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
160
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
dragonballz
dragonballz
MA
dragonballz
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
