Help with passing speaker wire through door jamb
hondarider
How do you get the speaker wire through the door jamb? I can pull the rubber boot piece out of the door when it's open and send a wire into it but i can't find where it comes out. I can't find the hole on the inside of the car. Any help is appreciated.
this shouldn't be that hard... you have a hole where the wire goes in, it comes out on the other side. it might just be blocked by other wires.
edit: poke around with your finger. or turn off the lights and shine a flashlight through one end of the hole, then look for the light.
Drill a hole in the door, and use a grommet. The second part of that is more important than the first part. You *will* shear a wire without one.
142
444
421
hondarider
hondarider
glidden, IA
Raven
    Jun 1, 2024
    May 31, 2024
