Help with running 4 speakers on a 2 channel amp!
  • 2
I'm running 2 front alpine speakers and 2 rear alpine speakers to a 2 channel kenwood amp and I get sound out of all the speakers but for some odd reason I can't hear certain sounds out of songs(example: snares switching between left and right speakers). All my positive and negative wires are hooked up correctly. I don't know if I need a crossover of some sort and if I do which kind because I'm not too familiar with how they work.
Thanks
run only the fronts off the amp. run the rears off the speaker outputs from the head unit. you don't need much sound out of the rears. it will likely sound a lot better.
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
481
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
535
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
564
JackPage
JackPage
Southern California
Jepalan
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
