Help with Soundstream Lil' Wonder crossover
  • 2
dragnix
LXIX
Ok, so i just got my Lil' Wonder III amps (LW4.500) in the mail and i'm wanting to use the active capable xover on the amp. The thing is I'm planning on bridging the amp to a 2ch. and run the mids active that way. However, the amp only has the bandpass option on ch.3 and ch.4, but not ch.1 and ch.2.
Here's my question, how would I go about using this amp in bridged mode and using the bandpass function for the channels? I was thinking of using y-adapters for the RCAs on ch.1 and 3 for one side and 2 and 4 for the other side instead of 1 and 2, then 3 and 4. Unfortunately this is not mentioned anywhere in the manual. Here's a link to the manual so you guys can get an idea of the amp's layout: http://www.soundstream.com/manuals/AMP/8118%20LW%20III%20MANUAL.pdf
I'll be heading to work now so I won't be able to respond until later on, but any help would be greatly appreciated. Thanks guys.
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
487
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
536
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
564
dragnix
LXIX
dragnix
Socal cuz i'm So cool
dragnix
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
