Help with strange amp install problem
  • 4
SRT8
Hi, I have a Clarion CMD4 deck on my boat. It used to have two speakers hooked up to a Clarion 4 ch amp, two speakers powered by the deck, and the other two amp channels going to a sub. It sounded good. I then bought a Polk Audio pdx2000.2, bridged it to power the sub, and kept the 4 speakers powered by the amp. The amps are hooked up by 2 volt pre outs from the deck, the sub on the "non fadeable" one. Amp and deck settings are all correct.
Problem is, speakers sound good, but absolutely no output from the sub. With gain maxxed, you can barely feel the sub vibrating by touch. I hooked up this amp in my vehicle to test it, with the same amp settings, and it pounds!! I checked, and the amp is getting 12v power in on the boat. So what the heck is going on here, I'm at a total loss?!
is the sub a dual voice coil? if you were powering the coils in stereo before, and now you've combined them at the amp, you need to ensure that polarity is not switched. that is the first thing i would check.
No, svc alpine marine 10". I swapped rcas, even input signal with the front rcas vs the sub rcas to eliminate all those problems, still no output. Anything else?
Someone suggested to me that when I took a V reading of 12V with the engine off, and it was putting next to no sound out, the amp is rated at 500W at 14.4V, and maybe that's why it was putting nothing out. Can anyone comment on that?
no it should still be fine at 12 volts.has to be something going on with the deck or amp.possibly bad ground,but the amp should be grounded at the battery
It's grounded right to the battery now. The amp worked in my vehicle when i installed it to test, and the other amp worked off the same set of pre outs, so its a real mystery!
Both are SVC 4 ohm. In car it's a Kicker Comp 10, in the boat it's an Alpine SWR-M100 4 ohm. I tried the Kicker sub off the boat amp with the same result, just barely vibrating.
It works!! I re did the sub amp ground, turned the gain all the way down on the speaker amp, turned up the deck, set the sub gain, re-set the speaker amp gain. Now she pounds pretty good.
I think it was the amp ground that was the biggest problem.
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
370
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
513
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
519
SRT8
SRT8
Edmonton, AB
SRT8
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
