Help with Variable tuning wall
  • 3
fritt
midwest
We have never built a variable tuned box of this caliber before. the box will be 38" high 39" wide and 22" deep (outside dimensions). the sides back top and bottom will be 2 layers thick and 3 layer face of 3/4". the inside will have PVC cut down for all corners and fully glassed inside.
What i need to figure out is how to be able to have at least 3 different tuning options, but easy enough to be able to drive to a comp then switch. example drive to comp tuned to 30hz and then retune to ~60 for spl purpose.
I will be running 2 18" upgraded DC LVL 4 18" off a Single DC 5k and later using the same wall to house 2 18" LVL 5 and 2 5ks.
Please any ideas would be help full! also I believe we will be doing the subs across the top and port at bottom.
How fast do you need to be able to switch? I'd think a plate bolted to the box with the port in it could work. I have also seen people use several ports, and plugging some to change/lower tuning.
well basically i want it to take less than 10 minutes for a switch. but from everything i have figured out with aeros wont give me enough port area when tuning lower for these subs as they want a min of 16" per cube.
also looking for a idea that i will still be able to make it look good. i want a good daily driver that i can get max spl out of. who says you cant have the best of both worlds?
DECWARE's Death Box II - High Output Subwoofer
Coarse this is for 12s but should give you an idea of a system that is easy to design, build, and change tuning on while in the vehicle.
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
414
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
521
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
537
fritt
fritt
midwest
fritt
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
