help??
  • 5
dude, Contact Nate at Excessive Amperage. Alternators can charge to whatever you need. Example: I have an adjustable voltage ragulator. I can charge from 13V up to 20V. I have mine set at 15.2V. and charging begins at 1000rpm. for my setup. Reaches max at 3K I think. and it does 285amps Max at max. so. Yes you can do if you got the $ and the need...
The best way to sustain that kind of power your looking at running is batteries.... Get yourself a battery bank
the biggest thing you want to consider, when talking about alts and batts... is what type of batteries your going to be using (rated AH), versus the amps output... if you add too many large batteries to a single alt, you can burn the alt up...
another REALLY big thing to consider, is when the alt reaches max output... some of the lower quality alt companies out there, use changes in pulley size, to aquire higher output... but that, can mean it wont hit this output until a higher rpm.... meaning, if your parked, and at full tilt, you'll either have to rev really high, or suffer some voltage drop... just food for thought
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
534
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
554
I went with Kenwood Exelon. Audio Control amp and speakers. It’s amazing! I’m glad I did some research before buying. Thanks guys.
5
626
aaronwhitlock3
Hodgenville, KY
mast240
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
