Help?
  • 2
MellowHype
My sub blew the other day and now i need to change my amps settings so i get bass through my components. I had the high pass filter on so there was no bass coming through the speakers, just from the sub. Should i leave the high pass on and change the frequency or turn it off? As i want bass to come from my speakers just not sure of the best way to do it.
My amp - Alpine MRP- F600
Comps - Alpine SPR-60c
Cheers!
You'll just have to play around with it. Crank it wide open on a nice punchy, bassy song and lower the crossover until the speakers start to distort or bottom out.
So shall i keep the HP filter on or switch it to off and then do what you said?
Cheers for the reply!!
keep it on for the process. If u find that you have it at its lowest point at full volume and they are still not distorting or bottoming out, turn it off and see if they bottom or distort then.
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
465
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
531
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
562
MellowHype
MellowHype
Uk, London
Why So Cereal?
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
