Help
  • 2
Doomroomceo
VA
I have a 2000 rx 300 with factory unit hooked up to kenwood 1000 max 600rms powering a 10inch p3. My problem started earlier when i lost all power to my amp. Now my amp cuts on when i cut off my car totally even with key removed when i cut the car back on with the radio the amp goes off. I have a converter hooked up to my back door speakers that has 2 sets of speaker wire a ground a remote a 12 v and output outlets can any body assist
398
518
525
Doomroomceo
Doomroomceo
VA
