Help
  • 3
Sicvitaest
CarAudio.com Newbie
I want to upgrade my audio system in my fully stock 2020 sentra by adding subs and an amp. The subs and amp are 1200 rms and I've looking into ways to prevent flickering or power draw. Some say new battery, some say new alternator, some say capacitors.
A good AGM battery and big 3 wiring using 0 gauge wire should be enough. I got a cheap AGM battery and it helped more than I thought it would. A high output alt is always the best option imo, but probably isn’t necessary for 1200 watts. If you plan on upgrading to bigger power amplifiers later, I’d go HO alternator. If you don’t have plans to run more than 1200 watts in the future, I’d just get a second battery and upgrade vehicle wiring under the hood to 0 gauge.
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
507
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
543
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
577
Sicvitaest
CarAudio.com Newbie
Sicvitaest
Illinois
SlugButter
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
