Hey Guys, Quick Question
  • 2
fire919
I'm testing for good ground connection @ my batt and amps....i am using a DMM to do this, the lowest ohms setting on the multimeter is 200 and i have it set there.....now when i test i get a reading of 1.5 @ my batt and amps....is that a good ground...will i have any problems. Thanks in advance.
a quick question but no quick answer. sorry about that.
your DMM isn't accurate enough to measure grounds directly. you need to operate within it's range. for that meter, you should use a resistor as well so you are within the normal range of the meter. a 100 ohm resistor would be perfect. start by measuring the resistor + wire leads directly. then add in the ground resistance and take the difference.
you should measure less than 1 ohm between amp ground terminal and battery negative terminal. less than 0.5 is preferred. note that there will be resistance in the connections between the DMM and the terminals as well, a few tenths at least.
The dirtiest hooker allive gotta smell better than fried Epoxy! (okay, that was a tad bit nasty, but funny nonetheless!)
8
hey
If it is a DVC4 ohm sub.. you can wire it up to a final 8 ohm load to run on that amplifier.. If its a DVC2 ohm sub... you can wire it up to a...
Pretty interesting interview/debate
4
550
  • Poll
That strikes me as overboard. We'll probably survive if a thread or two every week comes back from the dead.
18
3K
fire919
fire919
the bronx,NY
keep_hope_alive
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
