Hi guys need help Camry 2003 sound set up
  • 1
mk3_coolj
I have a Toyota Camry 2003 model Le 4 cyl. I would like to add an ampli and a ported subs and I want to use the factory stereo I had the loc ampli and subs but someone told me that there is a factory ampli in my car that need to bypass and I'm not sure where is it and how to do it do I need to bypass the factory ampli or I just do is connect the loc in the speaker wire and ampli cable to the battery also in my loc I don't have this blue wire the remote turn on how will I put this additional wire so it will not discharge my battery
It will be great if someone can explain the wiring behind the stereo
I really appriciate your help
Regards,
Mk3_CoolJ
Me too and then I have to paddle anywhere I want to go.
6
Got everything installed and running. It's definitely dragging my idle down a bit, I may bump my idle speed up a few hundred Rpm until the voltage...
those center spots shine out pretty far enabling me to see well on the dark highways.
22
3K
mk3_coolj
mk3_coolj
Los Angeles, CA
mk3_coolj
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
