HID problems
Boomin_tahoe
Hurtin' feelings errrday.
15,658
230
WA
Not too long ago I installed some HID's in my s10 p/u. Recently, sometimes the drivers side would not come on. So I would flick my hi-beams once or twice then those ones would come on. Problem is getting worse. I just fiddled with the wiring to see if maybe there was a bad connection somewhere or something wasn't tight. Found that the red wire was what I thought the issue, tried a few things seemed to have worked and now won't work at all. What can I do?
go with a better wiring harness.. what brand you using also??
just fixed a similar problem in my grand prix tonight by swapping in better quality bulbs...
Why did you bother commenting if you have nothing to say to help out?
Funny, I bought a set for my Tahoe also......no issues at all and......cost about the same.
You lack the fact that if anything is bought new, it's not always a guarantee it will work. Which is why companies offer warranties. It could be a soldering problem inside the ballast for all I know.
Gonna try and swap ballasts tomorrow.
30 bucks vs. 40 bucks? Not much in dollar difference.
Any ideas for me?
You see how the ones I posted have that second little box before you plug the lights in.... There different from what you bought... I had the ones you bought and nothing but problems... I took them out my truck and my wife car... Then I bought the ones I linked you and no problems since.
**** *** plug and play HIDS.. Do a proper projector retrofit or stick to halogen bulbs... Your heqdlights were not made for hids. The focal points are different. You will get nothing but glare and foreground lighting..
How old is the unit? My Pioneer died last month (manufacture date April 2021). Apparently they had component supply problems after Covid and...
689
I suspect it's an ignition problem rather than a transmission problem. Start with the basics: plugs, wires, coils, check engine codes. Does the...
773
Will you post a picture if the LC2i as it is wired. How did you set the output gains of the LC2i? What is the max voltage gain input on the amplifier?
I feel like its a bad set(Low tier set) of RCAs myself. I use Stinger Zero Noise and 4000-8000 series without any issues. Dayton makes a nice set...
Boomin_tahoe
Boomin_tahoe
WA
Boomin_tahoe
saints747
    May 7, 2024
saints747
    May 7, 2024
