Hifonics 1610
There a better 1500-1600 rms amp you guys recommend for around $250 that isn't a power wh0re
;7375797']Does rated? Yesbut... dirty as a corner wh0re' date=' power wise.[/quote']
What?
Rated power at 1% THD & N and 88dB Signal to Noise Ratio is dirty?
Please explain how you came up with "dirty as a *****, power wise".
This amp provides extremely clean power and among the lowest rated THD & N and Signal to Noise Ratio of any D-Class amp.
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
Ampz
Ampz
Philly
whitedragon551
maylar
    Jun 2, 2024
    Jun 1, 2024
