Hifonics brz2100.1d vs. Planet audio BB2400.1
I like the BRZ line seem to be strong. Im still up in the air on this BB2400 its cheap as hell and seems to do over 2k. I keep reading reviews that people keep popping subs with them. WHY? Is it cus there not running good enough electrical or they getting gain happy, I used to know a guy that the 2200series of planet audio dont remember exact model they just said 1700rms at 1ohm on the back. He had problems with them until he started feeding 7volts for input voltage to them and they never had a hiccup after that. So back to the BB2400s are they dirty power no matter what you do, or do you just need an alt batts and cable and a descent input voltage to be clean someone help me out?
they are not dirty power. clipping can cause voice coils to smell. i have never smelled mine or had a problem from it... those guys had to be gain happy or bass boost happy or yea they electrical system ******... they wont do 2400 mrs clean but you can get 2200rms clean out it. im bout to sell mine tho tryna get something bigger
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
He wants to strap the amps to double the output to one sub. Some amps allow you to "couple" them. This allows you to wire up the one sub powered...
bgowdy
Heroes are remembered, but legends never die
bgowdy
Campbellsville, Ky
bgowdy
Decebal
    Jun 10, 2024
