hifonics hfi2000d no sound
mudder53
I have two kicker cvrs 12", both are 2 ohm speakers, i have them wired in series so they have a 2 ohm load
I was using one of my old pioneer amps till I got my new hifonics hfi2000d in the mail the other day. I went to hook it up and the power light comes on but there is no sound. I am using an old Boss gain knob for my old amp still that connects via RCA cables. Since the hifonics amp comes with a boost knob I was wondering if I cant use the old one with it... maybe thats why I aint getting any sound? I have a very good ground, its about half way through the body in my car, so I know that isn't the problem.
The reason I think it isn't working is because I'm trying to use 8 gauge wire to power it for now. On the website it says the minimum is 4 gauge so I ordered a kit from knukonceptz and that will be here on Monday.
When my buddy got his 2000W hifonics, he accidentally hooked both + to one sub and both - to the other. Double check your speaker connections, sometimes they are layed out + - + - instead of + + - -.
it should "work" on 8 gauge, you really need 1/0 wire. get rid of the bass knob for now, they **** anyway, and double check all connections power,ground, remote etc. the amp doesn't know what size power wire your using, lol
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
12
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
5
3K
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
Just got off the phone with Matt, that box isnt going to work, but ill put this out there..... https://www.soundoffaudio.com/ Anyone in south...
23
898
mudder53
mudder53
Fargo, ND
big bass joel
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
