Hifonics or alpine
  • 4
Mjcruz
Im split right now I'm powering two type xs in a ford explorer all power is taken care of its a ported box I was curious of your thoughts of should I go with a
Hifonics 2500 Brutus elite or 2 alpine 1000 watt which one will give more power
Hifonics by far IMO....For the money, Id also check out some SStream Rubicons, and Okur amps as well for the money being spent.Good luck to you man.
2500 tops even with that amp you would have to make sure to go easy on the gains. make sure to check the classifieds here also you might be able to pick something up at a nice price if you dont mind buying used
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
564
Mjcruz
Mjcruz
Hammond, in
xShoWTeKx
