hifonics zeus
  • 2
playyamxz550
Memphis
well I can get almost brand new hifonics zeus of my freind for 250$ which is an good deal I think so im going to pick it up, my question is when I hook this up what do i do with the stock amp for the door speakers and what happens with the 50X4 on my deck, also how it has the 1000rms to now a sub the 5th channel, what do I do when I get an amp for my actally subs and do not use that 5th channell does it matter?
I had no idea what you were saying, let alone asking. If you wanted to know if you can run the 4 other channels off the amp and leave the 5th one alone then that's fine. It's a huge waste of money getting a 5 channel amp then not running the 5th channel imo.
Your deck isn't putting out ANYWHERE near 50x4 as well. Personally I think if you need someone to help you hook it up.
I have no idea as to door speakers and amps I was just asking. are the zeus amps bad because he also has a smaller 640w one I can get for 100$
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
12
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
5
3K
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
playyamxz550
playyamxz550
Memphis
playyamxz550
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
