Higg Level Input 4 channel bridged
  • 2
ddanko11
CarAudio.com Newbie
19
I want to bridge my 4 channle amp but I want to use it for left and right instead of front and rear I'm only concerned about the front stage with my amp and I'll use the the rear output of the radio to power my back door speakers, how would I do that since 1/2 bridged has a left and right and so does chan 3/4. would i just split front output and run all left to 1/2 then all right to chan 3/4
I wanted to bridge a 4 channel alpine amp the alpine mrv I have a touchscreen kenwood excelon just so you know. also how would I do this with high level inputs
How different amps process input is a factor.  Some 4 ch amps can use 2 ch of input to distribute to all 4 ch.  That would simplify your situation a little -- at least on the input side.
Otherwise, you'd use your left front and rear for ch 1/2 input and right front/rear for right input.
Then when you bridge ch 1/2 that SHOULD be your left speaker wire and same on the right.
I've done this more than once over the years and it seems like about half the time it comes out wrong and I just end up swapping rca's until my lefts/rights are where I want them to be.
I'd like to think my misses are due to weird amp input/output setups, but it's probably just me being stupid.  :thumbsup:
Factory. 2021 Chevy Silverado custom trailboss
9
620
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
5
699
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
607
I came across those too. Seen all the drivers out on the alibaba sight for sure. Wonder who is making them for PPI? Looked long and hard at those...
28
ddanko11
CarAudio.com Newbie
ddanko11
n2audio
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
