High RMS 8 inch depth?
  • 4
nbellowe
So, I have just built my first sub enclosure out of fiberglass! (round of applause) Now heres the part where I'm a moron. I built it without thinking much about mounting depth. Anyway, turns out I'm going to need one to mount in an 8 inch space. Is this going to be hard to do? I have an audiopipe 1000.1. Thanks!!
P.S. Is 8 inches considered a shallow mount?
Edit: Whoops, I'm a moron I left this out. 12", preferrably Double 2 ohm, and I have a budget of about 200.
It should have a lot of space. And after more measurements it is less than that, because it is mounted at an angle, so its much less deep on one end then the other. It has a lot of space, but I haven't filled it with water yet, so I'm not sure. Maybe 1.4 cubic feet or more?
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
303
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
906
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
760
nbellowe
nbellowe
United States
Austinw88
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
