hooked sub up and not working
  • 1
rpeterson57
15
Ok finnaly all my stuff came, jbl 1200.1 amp
audiobahn alum12x,
i made the box to specs and all
today i decided to test it out //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
hooked amp up to power rca ect, turned gain all the way down, turned HU on got nothing from sub,
so i turned the gain up till i could hear any thing about 1/4 way, and all i got was harsh noise and no real exscurtion, just sounded like the cone wasnt attached to the (spyder or what ever its attached to) the noise/sound came from behind the cone
so give me some ideas here
it was wired in parrallel, and then i tried series and still same problem
so when i turned the gain up it was just distortion
so is it power supply, rca or what is my sub blown or what
the rms for the sub is 1000
and im putting 900 at 3 ohm?
HELP
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
450
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
470
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
580
Don't forget Hoffman's Iron Law. You can have 2 of the 3: low end, efficiency/sensitivity or small enclosure size...
4
709
rpeterson57
rpeterson57
rpeterson57
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
