how do i figure out the cubic feet of a box i wana build 1
  • 2
Multiply lenght x width x the height in inches. Then divide by 1728 ( number of inches in a cubic foot ) and you will have your answer. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
I always planned on installing switches in the remote to the amps to shut them down when I want to. Admittedly I’ve never gotten around to it. An...
6
No different than powering multiple amps. I'd use a fused distribution block. Power each amp. Probably easiest to just add that to the existing...
So, to follow up, I got everything working properly again. If you refer to the photos I sent of the amp internals, you can see there is that white...
14
qxfosgatesvt
qxfosgatesvt
buffalo
ramos
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
